Adding Step Effector to Cloned Joint Chain?
I have a model flower that’s composed of one Joint Chain that has been combined with a model petal, allowing it to open and close. I’ve nested my petal into a Cloner object- which has given me radial array of petals, making my flower.
I’d like to use a Step Effector to do a time offset, allowing each petal to open slightly after the next, but I haven’t had any luck. I’ve attached the effector to the Cloner and the most I’ve been able to do is offset the Position, Scale, and Rotation.
Any ideas on where to go from here?
Steve
