Activity › Forums › Apple Final Cut Pro Legacy › Adding Space
Adding Space
Posted by Addison Stamper on June 1, 2009 at 6:20 pmOkay weird request. Is there a funtion that would allow me to add a second or two of space between every clip in my timeline?
Bret Williams replied 17 years, 4 months ago 3 Members · 4 Replies -
Joey Burnham
June 1, 2009 at 6:39 pmI don’t think there is. I have to do this sometimes and I just use the “select all tracks forward” tool “tttt” or Command+d and manually type in the offset. and repeat. 🙂
Bret Williams
June 1, 2009 at 7:11 pmHow about inserting a slug? Load a 2 sec slug into the viewer, and then use the down arrow to go from clip to clip. Down arrow, f9. Down arrow f9. Should be pretty fast. And if you insert the slug on a different track, you could then highlight all the slugs and delete when done.
