Activity › Forums › VEGAS Pro › Adding sound to powerpoint video .WMV
  • Adding sound to powerpoint video .WMV
    Posted by Campbell Killick on May 16, 2013 at 3:16 pm
    I am struggling to create a DVD of 5 powerpoint presentations on video
    As you probably know Powerpoint 2010 does a nice job turning a presentation with narration into a WMV file – either 960×720 or 640×480
    The properties are as follows
    Data rate 1366kbps
    Total bitrate 1686kbps
    Framerate 30 f/s
    ideo
    Format : VC-1
    Format profile : MP@HL
    Codec ID : WMV3
    Codec ID/Info : Windows Media Video 9
    Codec ID/Hint : WMV3
    Description of the codec : Windows Media Video 9 – Professional
    Duration : 2mn 37s
    Bit rate mode : Variable
    Bit rate : 411 Kbps
    Width : 960 pixels
    Height : 720 pixels
    Display aspect ratio : 4:3
    Frame rate : 30.303 fps
    Nominal frame rate : 30.000 fps
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.020
    Stream size : 7.71 MiB (46%)
    Language : English (US)
    So at this stage I want to add on a soundtrack, balance the levels and send 5 files to DVD architect. Windows movie maker does this very nicely. The resulting 1280×720 is clear and the 5 mp4 files burn onto DVD without any problem.
    But Movie maker is very limited and I am unable to set the audio levels and trim the soundtrack with the precision that Vegas movie studio platinum allows.
    I imported the clips into vegas using the “match media video settings” function to get the properties right.
    custom template (960×720, 30.000 fps)
    pixel aspect ration 1.00 (square)
    frame rate 30
    render quality best
    deinterlace interpolate
    adjust unticked
    After adding my soundtrack the preview looks good and I go to “make movie”
    Now the problem – whatever template I use seems to cause skip and flicker with black frames and frames out of order
    The mainconcept avc/aac standard 720 template seems right but it dosent work neither does the “burn it to DVD” option
    Its probably a small setting somwhere but I havent been able to find it
    I would value any constructive advice
    Campbell Killick replied 13 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
