Activity Forums VEGAS Pro Adding sound to media on the timeline
  • Adding sound to media on the timeline
    Posted by Tim Riordan on September 21, 2011 at 6:02 pm
    I’m using SV Pro 9. I’ve added several clips to the timeline in a project. When I selected them from the trimmer, it was set to the option “Select Video Only” (no audio). Is there a way to now designate or select the audio to also be active? I have several other clips on the timeline w audio, so the project does already have an audio track on the timeline. Or do I have to go back, re-edit the clips in the trimmer, and then use the “Select Audio and Video” option? I just thought there might be a way to do this before I go back and re-select them in the trimmer. Thanks,
    Tim
    “There are three kinds of people in this world: those who can count and those who can’t”
    John Rofrano replied 15 years ago 2 Members · 1 Reply
  • John Rofrano
    September 21, 2011 at 7:49 pm
    You can double-click the event to make a timeline selection. Then right-click it and select “Open in Trimmer”. This will open the media in the trimmer with the section being used by the event already selected. Finally, right-click the selection in the trimmer timeline and drag down to your audio track and tell it to only add the audio. This will add the audio back to the video.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
