Adding smooth camera movement over a composition with a low fps wiggle paths effect.
Until now I cannot get my head around how to get a smooth camera movement(25fps) over a composition that has a cartoon effect (‘wiggle paths’ effect) and therefore needs to maintain a lower (7fps) framerate.
What I already did was precomping the composition with the cartoon inside (7fps) and using another comp on top of that with a framerate of 25 and animate the camera in that comp. While I did that the resulting effect is that the wiggle paths effects makes a movement every frame (even while the ‘wiggle/second’ in the shape layers are set to 7).
So in short:
How to use 25 fps camera movement over a 7fps comp with ‘wiggle paths’, keeping the wiggle paths effect to 7fps.
Project file 9625_creativecowpl7.aep.zip
Any help would be awesome!
