Activity › Forums › Adobe After Effects › adding side stokes to mask (not to the entire rectangle)
  • adding side stokes to mask (not to the entire rectangle)
    Posted by Christine Chao on September 27, 2013 at 7:02 pm
    I know how to add stroke to mask but is there a way to only add stroke to two sides of the mask instead of the whole rectangle? Thanks.
    Mathew Fuller replied 13 years ago 2 Members · 3 Replies
  • Mathew Fuller
    September 27, 2013 at 8:48 pm
    Using 3d stroke plugin or generate stroke too i believe you can set a star end and percentage of stroke as well as positioning the offset.
    My Work:
    https://www.morecompletefx.com
  • Christine Chao
    September 27, 2013 at 9:05 pm
    I tried what you suggested but can only have one border on the side instead of both left and right border… is there any other way?
  • Mathew Fuller
    September 27, 2013 at 11:59 pm
    Split your mask in half and use one instance of the stroke effect for each half.
    My Work:
