Activity › Forums › Apple Final Cut Pro Legacy › adding shutter effects after the fact (XDCAM and FCP 6.02)
Posted by Mpigott on July 29, 2008 at 1:25 pmCafé LA : lafcpug
Your basic troubleshooting forum for all things FCP. Check the FCP FAQ Wiki before you post. The answer might be in there.Not registered? Click HERE to register now
Goto Thread: Previous•Next
Goto: Forum List•Message List•New Topic•Search•Log In
Posted by: mark@avolution (IP Logged)
Date: July 28, 2008 09:35AMI have discovered much later and well after everything was shot
that the Shutter switch on the XDCAM was turned off.
In other words, no motion blur was added in recording the footage
(which explains why it looks so stroby and choppy).Anyhow, is there a setting in FCP that will allow me to add in some motion
blur after the fact to help mitigate this situation?Craig Seeman replied 18 years, 2 months ago 6 Members · 13 Replies -
Chris Poisson
July 29, 2008 at 1:45 pmNot sure how in FCP but After Effects has frame blending which is quite good. Actually I think Motion does this as well.
Have a wonderful day.
Mpigott
July 29, 2008 at 1:52 pmCould you please elaborate on what filter or setting I would load up
the XDCAM footage into in Motion? -
Chris Poisson
July 29, 2008 at 1:55 pmMark,
I need to be in front of my edit machine to answer this, give me a half hour.
Chris Poisson
July 29, 2008 at 2:28 pmMark,
I’m not a Motion whiz, so maybe better help on the Motion forum, but anyhow, this may be a retarded method but it would probably work. Put a retiming “set speed” behavior on the footage and set the speed to 100%. In the properties inspector twirl down the timing arrow, there are a boatload of setting you could try, including optical flow.
More I think on this, in FCP you could put a deinterlace filter on it, and depending on which one you use may get a few blendi9ng options, Fields Kit from revisioneffects.com would give you this.
Craig Seeman
July 29, 2008 at 3:48 pmOdd because Shutter Off would likely increase motion blur depending on your frame of reference. It may depend on what the camera calls “shutter off” but that would mean shutter is at the frame rate. 1/30 for 30fps instead of 1/60 for example.
“Stroby” as in Saving Private Ryan is due to a very FAST shutter speed which is very much not the case with any camera I know of with Shutter Off.
Tom Brooks
July 29, 2008 at 3:53 pmThere’s a Motion Blur effect in FCP. Anything that moves gets blurred.
Mpigott
July 29, 2008 at 4:11 pm[Craig Seeman] “Odd because Shutter Off would likely increase motion blur depending on your frame of reference. It may depend on what the camera calls “shutter off” but that would mean shutter is at the frame rate. 1/30 for 30fps instead of 1/60 for example.
“Stroby” as in Saving Private Ryan is due to a very FAST shutter speed which is very much not the case with any camera I know of with Shutter Off.”
It was filmed at 24p and I checked the XDCAM Cinalta switch under the
lens and it was in the off position.
The footage was edited in Sequence:XDCAM 24p 35Mps VBR, so the sequence
settings are correct.When a pan occurs even slow, it seems stroby to the eye on the viewer
and when a HDDVD is made, the strobe effect translates to the HDVD.Also, all footage was brought in with the Sony XFer software, so it was an identical clone.
It really has me straching my head!
Ben Scott
July 29, 2008 at 4:16 pmin FCP load timeline clip to the viewer
then add motion blur and set details from the motion tab
wait quite a while
alternatively in Motion app you could try some sort of time filter like strobe or even a speed behaviour
dont use the speed changes in motion as suggested here this will not make any difference unless actually asking for changes to the speed
if more nice control needed look into reel smart plugin for motion blurring
Check my podcast at https://cowcast.creativecow.net/final_cut_pro/index.html
or my site at
https://www.benscottarts.co.uk/ – – – – – – – – – -
Mark Maness
July 29, 2008 at 4:19 pmWell…. that answers the question a little better.
Your watching your finished 24p project on a 60i monitor. Any motion will appear “stroby”. That is the translation issue between 24 fps on a 60 fields per second monitor.
Have you viewed your HDDVD on a 1080p monitor? Chances are it will look stunning.
_______________________________
Wayne Carey
Schazam Productions
https://web.mac.com/schazamproductions
schazamproductions@mac.com -
Mpigott
July 29, 2008 at 4:26 pm“Well…. that answers the question a little better.
Have you viewed your HDDVD on a 1080p monitor? Chances are it will look stunning.”
Actually, I have never viewed it on a SD monitor; only on a HD 1080p
monitor; and the footage still looks strobey.very odd
