Activity Forums Adobe After Effects adding shadow to green screen footage issue??
  • adding shadow to green screen footage issue??
    Posted by Sean Morton on February 15, 2012 at 6:39 pm
    Hi Community
    I am working on a 3d enviornment and trying to cast shadow from keyed image onto back wall. Added light and changed material options etc.
    When i am looking at 2 views, On the left view which is custom view 1 the shadow shows up perfectly. On the right view which is my active camera the shadow doesn’t show up at all.
    What am I doing wrong??? Obviously, i need that shadow on the active camera.
    Sincerely
    Sean
    Tudor “ted” jelescu replied 14 years, 6 months ago 2 Members · 12 Replies
  • 12 Replies
  • Tudor “ted” jelescu
    February 15, 2012 at 6:44 pm
    Are you using OpenGl?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Sean Morton
    February 15, 2012 at 6:54 pm
    Yes It is on.. Should it not be on??
    And why is it showing up on one side and not the other??
    Sean
  • Sean Morton
    February 15, 2012 at 6:56 pm
    Just turned it off… didn’t do anything.
    Sean
    February 15, 2012 at 7:03 pm
    OpenGl should be off – Adobe recommends that as well.
    Do a collect and post the project for us to take a look and see if we figure it out.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Sean Morton
    February 15, 2012 at 7:32 pm
    Hi again Ted
    I can do that and collect, however its 355 MB. A little high to upload. So when I toggle cast shadows on the keyed image, it works fine on the Custom View view. However, on the active camera view it does nothing. In addition, I am casting a shadow on a Boris continuum 3d text and it works totally fine.(in the active camera view) I am completely stumped.
    If i delete the solid layer (continuum 3d text) the shadow casting in the active camera of the keyed image still won’t work.
    I am keying the image with Primatte Keyer.
    Anybody??
    Sean
    February 15, 2012 at 7:35 pm
    Do you have the keyed footage precomped and that precomp as a 3d layer?
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Sean Morton
    February 15, 2012 at 7:43 pm
    Yup
    Sean
    you see, i could understand it not working at all and having a
    mistake somewhere, but why it would work in Custom View and not
    Active Camera is baffling to me.
    February 15, 2012 at 7:52 pm
    Duplicate your project, replace the footage with stills and see if the problem remains. If so, you can do a collect and post that project up.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Sean Morton
    February 15, 2012 at 9:30 pm
    So I rendered frame out to photoshop file. imported
    in and made it a 3D layer. It worked as it should.
    Now what??
    I am going to render out as an animation codec with alpha to experiment.
    I can’t imagine this being a codec issue!
    the original footage is h.264 file out of a canon5d.
    any other guesses as to what is happening?
    Sean
  • Sean Morton
    February 15, 2012 at 9:47 pm
    Boys I am going mental here!!!
    I am using CS5.5. Just tried the same thing with .mov with animation
    with alpha. Exact same issue. Moving light did nothing to the keyed
    image. It did move the shadow on the solid layer that is using continuum.
    As before, the custom view is correct, the active camera is not showing
    shadow from the keyed video image.
    I am calling Adobe for all the good it will probably do.
    aaarrgghh!!!
    I am running a 2011 mac book pro with 16Gb of Ram.
    Am I missing a setting somewhere about the active camera??
    Sean
