Activity › Forums › Adobe After Effects › adding shadow to green screen footage issue??
Tudor “ted” jelescu replied 14 years, 7 months ago 2 Members · 12 Replies
Sean Morton
February 15, 2012 at 10:07 pmOkay figured out the problem.. Still need advice though! I started from scratch and my layer stack is as follows.
Light1
Camera1
Video- keyed image
adjustment layer – fast blur added – and keyframed to blur more as she moved closer to camera
Solid – 3d text through continuum
Background image.So when i deleted the adjustment layer. the shadow then showed up
on both views.So why didn’t it work and how do i then do blur out the background
and add the shadow to it?? -
Tudor “ted” jelescu
February 16, 2012 at 9:24 amYep, yhat will do it- an Adjustment layer is a 2d layer. If it is sandwiched in between 3d layers is messes up the way 3d space works in AE- basically you have 2 3d setups, one in front of the other, that will not interact. Dave’s suggestion to use the blur directly on the layer and eliminate the Adjustment layer is the way to go.
Tudor “Ted” Jelescu
Senior VFX Artist
