Activity Forums Adobe After Effects Adding new masks on top of Roto Brush
  • Adding new masks on top of Roto Brush
    Posted by Dean Chapman on July 29, 2010 at 10:41 pm
    Is there a way to apply additonal masks on top of a RotoBrushed layer?
    It works when i precomp the layer, but not on the actual layer itself.
    Just to clarify, i have a layer that i used the RotoBrush on……then “Froze” the frames, went back to my main timeline and am trying to add a simple circle mask over the layer….
    thanks guys,
    dean
    Todd Kopriva replied 16 years, 1 month ago 2 Members · 1 Reply
  • Todd Kopriva
    July 30, 2010 at 2:45 am
    The order of operations is masks and then effects. If you apply a mask to a layer, then you’re going to mess with the effects that you’ve applied to the layer. Roto Brush is an effect.
    As you noted, precomposing works. Do that.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
