Activity › Forums › Adobe After Effects › Adding multiple elements to 3d camera track
  • Adding multiple elements to 3d camera track
    Posted by Ewan Maccormick on February 20, 2016 at 12:45 pm
    Hi guys,
    I have been trying to teach myself After Effects with mixed results! At the moment I am being driven absolutely mental with trying to add several elements to the 3d camera tracker.
    Basically I am trying to replicate this – https://youtu.be/W2ghhFqCqxc?t=55s From 55seconds. The scene with the maracana stadium in Brazil.
    I am trying to do it in After Effects and have tried it with the motion tracker but getting all these elements in there makes it too shaky, not smooth at all.
    With the 3d Camera tracker, I can get one element to attach, but none of the others.
    Do I need something like Element 3D to do this kind of thing, or am I missing something in AE itself.
    If anyone can spell out how to achieve the above video with the elements Map Marker, Circle, Text Box, Text all attaching themselves to the background as it moves, it would be a wonderful thing.
    Any help would be great and please be gentle with me on technical language, I am a relative noob to this.
    Thanks so much.
    Ewan
    Mike Sevigny replied 8 months, 3 weeks ago 4 Members · 6 Replies
  • Kalleheikki Kannisto
    February 21, 2016 at 8:09 am
    How do you add the first element that works, and the second element that doesn’t?
  • Ewan Maccormick
    February 21, 2016 at 8:21 am
    At first I was creating a null and camera and then parenting the layer to the null using the lasso. When I try to parent the second layer to the null it doesn’t take on the properties ie it still moves across the screen instead of staying still.
    Then I discovered that you could create multiple nulls and I tried this. But again I got the first element (an imported png of the map marker) to stick to null one, but then the second ( a shape layer) would not stick to any of the nulls.
    I don’t know if there is a particular order of doing things that I am missing, but I am creating all of the layers on the video layer, then running the camera tracker then trying to lasso them.
    February 21, 2016 at 1:12 pm
    It works that way — creating individual 3D nulls for the locations you are attaching things to — as long as the layers that you are attaching are also 3D. Make sure your layer’s anchor point is in the desired attach point, then hold shift when you parent to move the layer to the track null’s position.
  • Ewan Maccormick
    February 21, 2016 at 9:54 pm
    Hi Kalle,
    Thank you so much. It was the anchor points that I wasnt getting. I was chasing the elements all over the screen and trying to tie them up, but instead I discovered pre-comping and even then I couldnt work it and then your response came in and boom, it all worked perfectly.
    You are a gent, many thanks.
  • Callan Yeasyeet
    May 22, 2020 at 2:22 pm
    i have the same problem, i know this was 4 years ago, but when i press shift to parent my text to the null, it goes to the edge of the screen instead of going to the Null’s position.
  • Mike Sevigny
    January 8, 2026 at 6:24 pm
    I know this is an old thread, but I recently made a script called Tracker Solver that allows you to add 3D nulls in custom locations after solving the camera in After Effects.
    Here’s a short video on how it works:
    https://www.youtube.com/watch?v=YZnQF2DVhc8
