Activity Forums Adobe After Effects Adding more layers to an already imported Illustrator?
  • Adding more layers to an already imported Illustrator?
    Posted by Riley Tate on July 1, 2017 at 1:11 am
    Hey guys,
    Here’s a problem that has me scratching my head?
    I have a placed Illustrator file with 3 layers in an AE comp.
    I need to add ONE more LAYER to the original illustrator file
    I cannot get the 4th layer to show up when I “reload” the project files , it will up-date and reload OK but only the original 3
    Is there a way to do it?
    Cheers
    RT
    Riley Tate replied 9 years, 2 months ago 2 Members · 4 Replies
  • Mark Whitney
    July 1, 2017 at 4:53 am
    Perform a Replace Footage instead. Don’t know why AI is finicky this way when PhotoShop is fine with it.
  • Riley Tate
    July 1, 2017 at 5:28 am
    Thanks Mark,
    I gave that a shot but the options for the comp and the individual files is greyed out?. Am I doing it the right way?
    thanks
    RT
  • Mark Whitney
    July 1, 2017 at 6:51 am
    How are you initially importing; as footage or as a comp? That might be the issue, although it shouldn’t be. If you load as footage, then it’s a single file in the project window and it updates as expected.
    I just tested with an AI file imported as footage and in the project window simply selected Reload, and it updated with a newly added layer.
    If you’ve imported as a comp though, you can update layers but it won’t see add’l layers. You’ll have to re-import in that case. You can then bring the new layer into the original comp if you’ve already done work in AE.
    It’s confusing at times and I find that i always have to run some tests to refresh the memory.
  • Riley Tate
    July 1, 2017 at 7:20 am
    Ah, I think I got! So create a seperate file of the extra Illustrator element on its own and then load that as a single footage into the project window and then drag it into the previous illustrator comp along with all the other layers.
    A bit of a work around but good to know it can be done, thanks for you help ☺
    RT
