Activity › Forums › Apple Final Cut Pro Legacy › Adding more bass to tin can audio?
  • Adding more bass to tin can audio?
    Posted by Vincent Strader on August 2, 2010 at 9:31 pm
    I see all the Apple and Final Cut Audio filters in the drop down menu. Messing with some of them. Wondering if anybody has had an issue similar to this and which filters or combination of filters and settings you used in the control panel?
    FCP 7.0.2
    Message Signature:
    I don’t have any charming or witty things to put in my signature. So as Peter Griffen says, “That’s may mama!”
    Ty Ford replied 16 years, 1 month ago 4 Members · 3 Replies
  • John Fishback
    August 3, 2010 at 8:02 pm
    Replacing lost information is always a challenge. You might have some success with the Apple/FCP filters, but it depends on what you’re starting with. Waves has a bass plugin that uses what they call psycho-acoustic technology. The plugin allows you to select a fundamental freq and it adds in harmonics of that freq thereby creating the impression of more bass. I don’t know if you can use it directly in FCP. I’ve used it in Pro Tools and it works well in the right situation.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • Terry Mikkelsen
    August 3, 2010 at 8:48 pm
    The ability to create sub-harmonics is also available in Soundtrack Pro. The effect is called “SubBass”. Send your FCP project to Soundtrack Pro and see if the additional filters and effects there help you out at all.
    Tech-T Productions
    http://www.technical-t.com
  • Ty Ford
    August 8, 2010 at 1:48 pm
    OK, it sounds thin, but where and how much do you add?
    Or, should you really reduce HF, or a little of both!
    First, think about what your monitoring setup is. If you have lap top speakers or speakers with woofers smaller than 10″ (diameter), you can easily miscalculate what you need unless the program is played back on a similar system.
    What sounds in the production do you think are tinny?
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
