Activity Forums Maxon Cinema 4D Adding luminance material selected clones
  • Adding luminance material selected clones
    Posted by Brian Mills on May 20, 2015 at 9:16 pm
    I am trying to make a ceiling with tiles and lights. I made with cloner and selected clones to be the lights which I want to add a luminance texture. The other non selected clones will have a different material applied.
    Cant seem to get this to work.
    Help!
    Brian Mills replied 11 years, 4 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 21, 2015 at 3:39 am
    Here’s one way to do it:
    * place two copies of the tile object under the cloner and give the second one the luminance texture;
    * set the cloner’s Clones method to “Sort” (Object tab);
    * assign a plain effector to the cloner, turn all the effector’s parameters off, and set “modify clone” to 100%;
    * drag your mograph selection tag into the effector’s Selection box (effector tab).
    Example: 8850_lighttiles.c4d.zip
  • Brian Mills
    May 21, 2015 at 1:04 pm
    Thanks alot for the help!!!
