Activity › Forums › Apple Final Cut Pro Legacy › Adding in and out to 150 pictures
Posted by Joe Horne on December 12, 2008 at 1:06 pmI have about 150 pictures that I am stringing together in the timeline. I want each picture to come into the Viewer with in and out points that mark it for lasting .5 seconds. What is the best way to apply this across the board without doing each one manually?
With appreciation,
Joe
Ross Daly replied 17 years, 9 months ago 6 Members · 7 Replies -
Rafael Amador
December 12, 2008 at 2:47 pm -
Peter Wiggins
December 12, 2008 at 3:43 pm -
Joe Horne
December 12, 2008 at 5:05 pmI have tried changing the preferences, however, it doesn’t accept what I enter. Or it puts a different number in. This seems odd, no?
The XML app looks cool but I have not gotten it to work successfully yet.
Thanks for the suggestions. Any other ideas?
Rafael Amador
December 12, 2008 at 5:15 pmIf you set 15 frames (12 in PAL land) should work. And if doesn’t work you should have a look to why doesn’t work.
Rafael -
Steven Gonzales
December 12, 2008 at 6:32 pmI believe you can select all the stills, put them in the timeline, then select all, control-click for the contextual menu, then set duration to the appropriate length, and they will all reset to the new duration.
David Bogie
December 13, 2008 at 4:47 pm[Steven Gonzales] “I believe you can select all the stills, put them in the timeline, then select all, control-click for the contextual menu, then set duration to the appropriate length, and they will all reset to the new duration.”
I’m not at my FCP machine to test this but it sounds reasonable. Removing the gaps between them will tedious!
bogiesan
Ross Daly
December 18, 2008 at 4:13 pm“Removing the gaps between them will tedious! “
No – it needn’t be. Just move the last clip up to V2, select the empty area in V2 to the left of the last clip, and hold down delete. It will error out once all of the gaps have been removed. Voila!
I still agree that the still duration is the easiest way to do this though. 6 of one…
