Activity Forums Zaxwerks adding image to 3D object ??
  • adding image to 3D object ??
    Posted by Matt Bishop on June 15, 2006 at 1:54 pm
    Hello All !
    I am new to using the invigorator classic so I am reading the book and playing as I go. Here is my question and situation.
    I have created a simple square object in Illustrator. I put that into AE using the plugin..all is well. I then save a picture of the ‘material’ that I want to show on that box. The picture is a jpg the same size as the box I created. When I apply this picture as a material and put it to the box, it shows up just fine, but.. that picture puts itself on the back and 4 other sides of the 3d box I now have. How can I get it to display the picture on the front and have the sides and back show a solid color or different border color altogether like the nbc logo for example.
    Thanks in advance !!
    Matt
    Matt Bishop replied 20 years, 2 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    June 16, 2006 at 12:48 am
    Matt,
    You need to explore the material set-up area.
    There, you can assign different materials to the front, sides and rear faces of your cube. You’ll see a cross section of your object and bins into which you drag different materials.
    Does this help?
    Jon
  • Matt Bishop
    June 18, 2006 at 11:03 pm
    Yes this fixes everything..and I just happened to come across that part in the book now so all is well! Thanks for the info!! always appreciated!
    Matt
