Activity Forums Apple Final Cut Pro Legacy Adding Graphic with FCP
  • Adding Graphic with FCP
    Posted by Joel Perez irizarry on December 22, 2006 at 2:16 pm
    I’m editing a commercial in 720p DVCPRO HD. I have a keyable animated logo with HD resolution. When I put in over the image it looks fine but when I render the animation It looks broken up and pixalated. What can I do? Should I trie doing it in Motion or After Effects?
    Kevin Monahan replied 19 years, 9 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    December 22, 2006 at 3:41 pm
    Judge the quality of the logo externally on a video monitor if you’re not already…. the Canvas only shows a proxy of the actual picture quality you’re working with. I presume this logo has an alpha channel? It probably looks fine, you just can’t see it if you’re not viewing it externally on an HD monitor… Even an SD monitor would be better than the Canvas for any sort of judgement of quality.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Kevin Monahan
    December 22, 2006 at 5:04 pm
    Make sure the RT popup menu to:
    Safe RT
    High Quality
    Full Frame Rate
    Check off all qualities in the Sequence > Render Menus
    Make sure graphic lands on whole, even numbers
    Monitor to NTSC
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
