Activity › Forums › Adobe After Effects › Adding Gaps to Shape Layer Stroke Dashes Adobe After Effects Adding Gaps to Shape Layer Stroke Dashes Posted by Jordan Hull on February 22, 2019 at 1:35 am I am wondering if it is possible to add “Gaps” to shape layer stroke dashes. I can clearly see “Dashes” and can achieve the result on the top of attached image. I’m hoping to achieve the result on the bottom of the attached image. Thanks in advance. Jordan Hull replied 7 years, 6 months ago 2 Members · 2 Replies 2 Replies Greg Gesch February 22, 2019 at 3:25 am Hi. Press the + again and you will get a Gap spacer heading. Jordan Hull February 22, 2019 at 5:44 pm Solved! Thank you, that was easier than i thought. Reply to this Discussion! Login or Sign Up Public All Members My Connections Only Me PublicAll MembersMy ConnectionsOnly Me Public All Members My Connections Only Me Reply to this Discussion! Login or Sign Up
