Activity › Forums › Adobe Premiere Pro › adding foley sound effects
  • adding foley sound effects
    Posted by Bodybuildingbs on July 24, 2005 at 4:52 pm
    I am adding foley footsteps and it is driving me crazy…is there anyway to play the timeline and press something on the keyboard that would leave a marker and then I could go back and have a rough idea of where to begin with the footsteps?
    Thank you.
    I know this is a simple answer and its staring me in the face but I cant figure it out..
    Josh Costa replied 16 years ago 4 Members · 6 Replies
  • Steven L. gotz
    July 24, 2005 at 5:03 pm
    The asterisk key on the numeric keyboard (not above the 8). Play the timeline, tap the asterisk key. When you stop the clip the markers will be there.
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Bodybuildingbs
    July 24, 2005 at 6:46 pm
    Thank you very much.
  • Craig Howard
    July 25, 2005 at 12:09 am
    Using the technique described by Steven you could place a marker on each footstep and then automate a sequence to the timeline.
    i.e – record one footstep, dupe it a number of times and automate it to the markers.
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Bodybuildingbs
    July 26, 2005 at 4:32 am
    Thank you how do you dup and then automate to markers..please advise.
  • Craig Howard
    July 26, 2005 at 10:00 pm
    Hey Jack
    Could I suggest page 124 of the manual will explain this better than anyway I can.
    …and duplicating a clip can be done many ways. I would edit the footstep 1st, save as a named file.
    Depending on how many footsteps are required would determine next step ( pardon the pun)
    duplicating the named file a number of times by renaming each (name +number suffix)would be one consideration.
    Craig
    Auckland
    New Zealand
  • Josh Costa
    September 23, 2010 at 6:14 am
    What if I’m using a laptop and the only asterisk is the one above the 8?
