Activity Forums Adobe After Effects Adding effects (ie: Shatter) to the midpoint of a short video clip
  • Adding effects (ie: Shatter) to the midpoint of a short video clip
    Posted by Michael Kavanaugh on February 1, 2006 at 5:53 pm
    I need help in placing an effect like “Shatter” anywhere on the timeline to a short video clip. I have been successful in applying the effect but it occurs at the beginning of the clip. I would like the effect to happen later in the clip at my choosing. I have put a little time into trying to place/set markers for the effect to happen. I missed the memo somewhere?!?!
    Thanks in advance!
    Mike
    Tim Kurkoski replied 20 years, 7 months ago 3 Members · 2 Replies
  • Jim Kanter
    February 1, 2006 at 11:56 pm
    Split the layer at the point where you want the shatter effect to begin and apply the effect to the later section.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Tim Kurkoski
    February 2, 2006 at 12:02 am
    Yes, the Shatter effect is designed this way.
    There are two solutions:
    Easy: Split the clip (Edit > Split Layer) at the point where you want the shatter to begin, and apply Shatter only to the second instance. Downsides: if you’re using other effects or transformations you’ll have to coordinate between the two instances or tie them together with an expression.
    Harder: Set a Hold keyframe of value 0 for the Radius property in the Force 1 section of the shatter effect at the beginning of the layer. Then set a regular keyframe with the desired value at the point where you want it to start shattering. Downsides: None, really. It’s just more of a pain to set up.
