Activity › Forums › Adobe After Effects › Adding Effect to white Solid
  • John Cuevas
    January 21, 2014 at 2:52 am
    If you sample the white bar, it’s not pure white. I was able to recreate that effect using 2 instances of CC Light Sweep. You could easily sweep the effect across the border, if you wanted with couple of keyframes and an expression picking the Center from one effect to the other with a bit of an offset.
    7025_whiteedgesfolder.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Brandon Adam
    January 21, 2014 at 2:57 am
    Thank you very much John, that is actually the solution I needed!
