Activity Forums Maxon Cinema 4D Adding detail to a curved span of a building model
  • Adding detail to a curved span of a building model
    Posted by Ron Moore on August 1, 2011 at 2:21 pm
    I’m looking to create detail on a long, curved section of an architectural model made from a spline. I need to have several horizontal grooves in the span and maybe 25 evenly-spaced vertical grooves. I tried placing a bump map in the texture but couldn’t get the pattern to repeat nearly enough times over the full span. Using the knife tool is hit and miss since I can’t get exact spacing of 25 different vertical cuts (actually 50 parallel cuts) since I’d need to extrude each cut out somewhat. There must be a better way.
    Brian Jones replied 15 years, 1 month ago 2 Members · 1 Reply
  • Brian Jones
    August 2, 2011 at 3:56 pm
    the Plane option of the knife tool has the Slice option but if your model is curved that may not be of use.
    You can definitely repeat a pattern with textures but it may be much easier to do it with the Texture Tag – Tiles options
