Activity Forums Apple Final Cut Pro Adding clip to multiclip
  • Adding clip to multiclip
    Posted by Hoss Wuerslin on August 2, 2012 at 2:41 pm
    Hey out there;
    So a new clip has shown up that needs to be added to my multicam clip cause it’s got the sound i need. This day is starting long.
    Can I select the multicam clip and the new clip and… hit a “magic button” that says please combine/sync to multiclip, or do i need to create a brand new multiclip and start over?
    Thank you for your help.
    Hoss
    Jeremy Garchow replied 14 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 2, 2012 at 3:11 pm
    Double click the multiclip to open the angle editor.
    Find the small drop down menu at the end of the filename on any angle and click it.
    Choose “Add Angle” from that drop down.
    Add the video to the new angle.
    From here, you have to choose how to sync that angle which might mean you have to choose a “monitoring angle” to sync to, and then sync the new angle to that monitoring angle.
    Hope that makes sense.
    Jeremy
