Activity Forums Adobe Premiere Pro Adding blank spaces between edit segments
  • Adding blank spaces between edit segments
    Posted by Eric Merklein on July 20, 2016 at 5:52 pm
    Greetings.
    Is there a way to add blank space between 2 edits? In Avid there is a pull-down called Filler that you can select, and it behaves like a source. I’ve looked all over the place and can’t see how to do this in Premiere Pro.
    Thanks much.
    Eric
    Many thanks.
    Eric Merklein replied 10 years, 1 month ago 3 Members · 5 Replies
