Activity › Forums › Telestream › Adding audio source to 50 slides (pngs)
  • Adding audio source to 50 slides (pngs)
    Posted by Bob O’hearn on February 9, 2011 at 7:18 pm
    Hi all,
    I have a corporate presentation next week that I will need to convert 50 slides to pngs and broadcast along with a presenter that I will be switching back and forth to. I will need the source audio from the presenter to be assigned to each slide (graphic). My question is: Do I have to assign the source audio to each png slide separately or is there a way to set a default. Just got off the phone with Telestream and they said they would get back to me later. That didn’t sound reassuring to me so I am turning to where I usually get the best info. Thanks in advance.
    Bob O’Hearn
    Craig Seeman replied 15 years, 7 months ago 2 Members · 1 Reply
  • Craig Seeman
    February 10, 2011 at 12:34 am
    If you assign audio source to a Master Layer it’ll remain live even if you cut to different shots, video, stills.
    Also if you have Wirecast 4 Pro you could do it in the Audio Inspector if you bring in the audio as a “Live Source.”
