Adding an animated bug in Avid Xpress Pro
I’m trying to add an animated bug into an hour programing all the way through into my Avid Xpress Pro sequence. What I have been doing is taking the five minute avi file and importing it and then keying out the red that is behind the bug. The problem with this is I have to keep pluging the clip in every five minutes and then adding a new chroma key which takes forever for my machine to render. My boss says that there is an easier way to do this and other editors in the past just used some sort of roller (I’m guessing in trim mode) and were able to drag the clip across the entire hour, but I’m not able to do it. If anyone has any idea of an easier way I could do this that would be great because right now most of my time is spent rendering.Thanks!
