Activity Forums Adobe After Effects Expressions Adding a variable to keyframes
  • Adding a variable to keyframes
    Posted by Ahmed Raad on April 17, 2020 at 3:46 pm
    Hi everyone, my question is so easy for most of you.
    I want to add a variable (Slider) to (offset) range slider that has two keyframes the first one (let’s call it (A)) is <0 and the second one (B) is >0, so if I set 5 to the variable slider (A) will be (-5) and (B) will be (5). So the value will increment by time (-5,-4,..0..4,5).
    I don’t want to use (ease or linear) because it does not looks smooth enough to me, so I want keep using keyframe to play with (graph editor).
    I know I can do it without expression, but I have to do this many time in my project and I want learn how to do it.
    THANKS
    Ahmed Raad replied 6 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
