adding a value to a subsequent layer’s property
I have a text layer which I’ve put an opacity text animator.
I’m using opacity to reveal each letter one at a time using the offset parameter.
So with a start of 0 and and end of 1 and offset at zero, the first letter of my text line is visible.
I can dupe my layer and set that layer’s offset to 1 and that will reveal the second letter.What i want is an expression that I can put on the 1st layer’s offset so that each time I dupe the layer the new layer will have the offset value increase by one, so that all I have to do is keep hitting apple-D and all my letters will be revealed on it;s own layer,
I suppose what i really want is how to do this with all sorts of parameters.
Say I want each duped layer to be 10 bigger in scale than the previous, etc.
