Activity Forums Adobe Premiere Pro Adding a timestamp
  • Adding a timestamp
    Posted by Schnard on October 12, 2005 at 7:08 pm
    How can I add a timestamp ontop of my project. I want something I can use when I export a rough draft for editing/approval. A timestamp would make sense for my peeps to note the specific areas. Is there a simple program out there ??
    Schanrd
    Zachary Leckscheid replied 14 years, 4 months ago 9 Members · 8 Replies
  • 8 Replies
  • J. D. mack
    October 12, 2005 at 8:26 pm
    Since rendering a time stamp over my video takes waaaay too long, I use an external time code generator with a video output. I’m using the Horita TG-50, but there is a similar item on eBay right now.
    https://cgi.ebay.com/Horita-RM-50-8SEL-VLT-Time-Code-Translator-VLT104_W0QQitemZ7357217047QQcategoryZ3278QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
    Basically, you run the NTSC output of your system through this device, and it will output your video plus a window with timecode, which you can record on anything you want. Because you start the time code generator by hand as soon as your video starts playing, this is not a frame accurate solution. But if plus or minus half a second works, then this can save a lot of time over rendering a time stamp (at least, in Adobe Premiere 6.5).
    J. D.
  • Mike Velte
    October 12, 2005 at 8:39 pm
    There is a plug-in that will add timestamp to your movie…maybe someone will chime in on that. I simply overlay a small movie that does this. I have a 1 hr clip for free download on my web…under downloads.
    https://www.video2stream.com
  • Steve Freebairn
    October 12, 2005 at 9:20 pm
    If you have after effects, you can just export an hour long video with comp size 200×40 and use the numbers plugin. Export it and then just place it in a video layer above the rest of your project.
  • Craig Howard
    October 12, 2005 at 11:14 pm
    DVdate is the Prem plug in and it works a treat.
    Very good value, low cost, customiseable.
    Google search it
    Craig
    Shooter Film Company
    Auckland
    New Zealand
    (Premiere Pro 1.5 / Matrox TRX100 XTreme Pro)
  • Luan Van le
    October 14, 2005 at 7:31 am
    Just in case you’re still looking. There’s freeware called Timecode Frame Generator 2.0. It’s a standalone program that will create a counter, add dates, and you can adjust almost any parameter. The link is https://www.2writers.com/download.htm
    Luan
  • Shaun Mcfadyen
    January 23, 2009 at 8:04 pm
    Mike,
    I would love to use the time stamp video you link to here but the link is broken. Is there any way you can get it to me or make it available for me to download?
  • Eddie Lotter
    January 23, 2009 at 10:15 pm
  • Zachary Leckscheid
    May 18, 2012 at 7:06 pm
    If you go to the ‘new item’ button in the Project window you can make a transparent video layer and make it the length of your comp, then apply a Timecode effect to that layer. Works well enough for me.
