Activity › Forums › Adobe After Effects › Adding a symbol to this expression
  • Adding a symbol to this expression
    Posted by Simon Jones on November 19, 2019 at 2:53 pm
    I’m using the following expression to generate values for counters used within a game (thanks to Dan Ebbert and Walter Soyka) :
    frames = 15;
    clockStart = 1;
    rate = (1/thisComp.frameDuration) / frames;
    clockTime = clockStart + rate*(time – inPoint);
    Math.floor(clockTime);
    The question I have is that I wish to add a £ or $ symbol in fornt of the generated number. Anyone know how i’d do that?
    Cheers
    Simon
    it’s all about the X and the Y
    Cassius Marques replied 6 years, 10 months ago 2 Members · 1 Reply
  • Cassius Marques
    November 19, 2019 at 4:52 pm
    If its a field that accepts strings you just need to add (“any string”) + before the result (which is Math.floor…)
    such as
    frames = 15;
    clockStart = 1;
    clockTime = clockStart + rate*(time - inPoint);
    ("$")+Math.floor(clockTime);
    Cassius Marques
    http://www.zapfilmes.com
