Activity › Forums › DaVinci Resolve › Adding a LUT
  • Adding a LUT
    Posted by Benjamin Dewalque on March 30, 2012 at 7:22 pm
    Hello,
    I would like to add a LUT to resolve. When i put it into the right directory it isn’t seen.
    What should be the extension of the lut and how this lut must be written inside ?
    It is not an alexa lut.
    David Braman replied 13 years, 4 months ago 3 Members · 3 Replies
  • Bill Ravens
    March 31, 2012 at 10:47 am
    U didn’t mention your platform. On a PC, the LUT file goes in C:\Program Data\Blackmagic Design\Davinci Resolve\Support\LUT. Then you can apply the LUT within a node.
  • Benjamin Dewalque
    March 31, 2012 at 12:26 pm
    I’m on a mac. My problem is not the place where to put the LUT, when i put the lut the software doesn’t see it.
    The extension of the file is .txt, i’ve tried to change the extension in .cube and in .dat, in those case the software can see the lut but nothing happen on the image (like if not lut were applied).
  • David Braman
    May 10, 2013 at 4:41 pm
    I’m on a pc, but that path does not exist beyond \DavinciResolve. Any other suggestions?
