Activity Forums Maxon Cinema 4D adding a logo over a glass material
  • Brian Jones
    March 14, 2013 at 2:03 pm
    the logo should be it’s own separate material with an alpha channel that goes above (to the right in the AM) of the glass material
  • Victor Camacho guerrero
    March 14, 2013 at 2:15 pm
    Hi Bryan, that works great!!
    I have another funny situation, i created the logo in Photoshop. The main letter which says Dr Lewinns looks fine, but the rest of the text ( the small one) it looks like a black boxes. Any idea how to fix that??
    By the way , for this model which projection would you recommend??
    Not every single projection allow you to use the texture tool right?
    Many thanks man!!!
  • Brian Jones
    March 14, 2013 at 2:42 pm
    only UVW doesn’t give you the texture tool (well it does but only offsets and scaling work, rotations are ignored) the others all do. In this case go with Cylindrical since it’s a cylinder.
    Can’t tell about the PS I’d have to see the file.
    March 14, 2013 at 2:57 pm
    Thanks so much Bryan,
    for the PSD i realized what happened. Because of the soft option in the Alpha channel, I could not see the letters in detail.
    Thanks so much, you saved me a crazy deadline!
    cheers
    March 14, 2013 at 4:15 pm
    Hi Bryan ,
    sorry another question, when I try to create the product of the middle, and I try to load some white text over the black material , if I use the alpha channel, even giving a white color in Photoshop to the text, the text loads as black in the material.
    Any way to change that to white???
    Many thanks
  • Brian Jones
    March 14, 2013 at 5:46 pm
    it should give you the color of whatever is in the Color channel (and it’s white by default) with the alpha channel controlling the shape
    March 14, 2013 at 5:51 pm
    awesoma man!
    Many thanks!!!!!!!!
