Activity Forums Adobe Premiere Pro Adding a key frame with same settings?
  • Adding a key frame with same settings?
    Posted by Matthew Polack on January 22, 2008 at 5:37 am
    I enjoy using keyframes for animation effects in PP2 but I am wondering if there is an easier way to add a new keyframe further down the timeline when I in fact don’t want the settings to change.
    eg.
    I keyframe scale and postion at start of clip
    I move 2 seconds in and set scale to say 80%.
    I want scale to stay at this 80% for 3 seconds..so I move the CTI 3 seconds further along…
    now at this point I just want to set a new keyframe at 80% so I can then change the scale effect to something else later in the clip …
    if I press the stopwatch..it will ask to delete all keyframes…I just want another keyframe…
    The only method I have is to physically drag the scale slider one way..then back other way to exactly same setting…..
    this works..but is just a bit clumsy..
    Is there some other button/shortcut that will simply add a new keyframe..using the existing setting?
    Thanks.
    Matthew Polack replied 18 years, 7 months ago 1 Member · 1 Reply
  • Matthew Polack
    January 22, 2008 at 5:39 am
    Think I just answered my own question..simply click the button between the arrows…apologies for taking up posting room! 🙂
