Activity › Forums › Adobe After Effects › Adding 200 lights to 200 Null objects?
  • Adding 200 lights to 200 Null objects?
    Posted by Kevin Camin on May 2, 2012 at 8:31 pm
    I’m exporting some 3D data from Cinema 4D. I basically created a light bulb wall and am generating a 3D null for each light bulb. I want to put an after effects light in each of the spots the generated nulls are in (and then I’ll be using Video Co-Pilot Optical Flares plug-in to turn each of those after effects lights into a flickering flare).
    Is there an easy way to assign the AE lights to the nulls? I’m trying to avoid parenting 200+ lights to each null or copy and pasting the positions.
    Thanks.
    Best regards,
    Kevin Camin
    James Poulakos replied 12 years, 5 months ago 5 Members · 7 Replies
  • 7 Replies
  • Kevin Camp
    May 2, 2012 at 8:51 pm
    you may be able to find a script that can do something like this…
    you could try this using a simple expression for position of the light like this:
    thisComp.layer(index-1).position
    the light would then just look at the layer above it and use it’s position. you would still need to re-order the layers so that a given light was position bellow it’s corresponding null…
    or you could add all the lights at the bottom of the comp and modify the expression like this to avoid having to move the change the layer orders:
    thisComp.layer(index-200).position
    this way you’d create one light, add the expression and duplicate it out 199 times, then you could shy/hide the nulls… or if you don’t need the nulls, you could convert the expressions to keyframes and delete the nulls.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Walter Soyka
    May 2, 2012 at 9:25 pm
    That’s a really elegant (and fast) solution, Kevin!
    Walter Soyka
  • Joseph W. bourke
    May 3, 2012 at 1:30 am
    Kevin –
    This may or may not help you. There’s a free script called Null Swapper, that’s made for more or less what you’re looking to do. It only works, from what I understand, in CS5.5:
    https://provideocoalition.com/index.php/motiongraphicsvizfx/story/null_swapper_-_plexus_particular_utility_script/
    I hope that’s what you’ve got – it could save a whole lot of time. Good luck!
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Kevin Camin
    May 3, 2012 at 6:04 am
    @Kevin: Thank you, that is indeed an elegant solution. Is there a way to copy and paste an expression to multiple layers at a time?
    @Dave: I’m creating AE lights in conjuction with the Video Co-Pilot Optical Flares effect. There is no actual light being generate from the lights, but it being used as a position coordinate for the flare effect to impose on. It works extremely well, and is fast. If you want to create a nuanced wall of light, this is a good way.
    Thanks so much everyone.
    Best regards,
    Kevin Camin
  • Kevin Camp
    May 3, 2012 at 2:55 pm
    [Kevin Camin] ” Is there a way to copy and paste an expression to multiple layers at a time?”
    yep, select the property of the layer that has the expression and choose edit>copy expression only. then select all the layers that you want to paste the expression onto and then ‘paste’.
    also, i had said that the lights should be at the bottom of the comp, however, that was assuming that the nulls were at the bottom of the comp to start with… since the expression is using the indexes of layers relative to itself, it would be more accurate to say the group of 200 lights should be bellow the group of 200 nulls, if you had a camera or other layers in there, they should be either above or bellow the nulls and lights, but not in between them… though the expression could be modified to account for that if needed.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camin
    May 4, 2012 at 5:22 am
    Thanks, Kevin!
    And thanks, Joseph for the link to the script. I unfortunately am still working off CS5. But this will come in hand in the future. Thanks, again.
    Best regards,
    Kevin Camin
  • James Poulakos
    April 23, 2014 at 2:58 pm
    Kevin Camp’s answer just helped me, today, with After Effects CS6. I wanted to thank you all, for the question, the answer, and the forum where we can share them. Thanks! (and thanks to the site’s sponsors and advertisers).
    The workaround using layer index numbers really helps. Now that I’ve seen that snippet of code, I bet I’ll find other uses for it, too.
