Added multicam audio angle not showing in inspector.
Just checking to see if this is a bug or if I am doing something wrong.
I added an audio angle to a multicam clip, but that clip angle is not showing up in the inspector under the channel configuration for audio.
The goal is to essentially replace the working audio I used for the edit with cleaner audio while maintaining those edits. This is why I added it as an angle to the multicam clip.
The new angle shows up in the angle viewer, but cannot be seen from the storyline as expanded audio components nor when in the inspector when selecting the multicam clip in the storyline.
Any ideas?
Tangier
