Activity Forums Apple Final Cut Pro Legacy Added Firewire Card Question
  • Added Firewire Card Question
    Posted by Michael Allen on August 31, 2007 at 3:45 pm
    Added a firewire card to G5. The computer sees the card (or it shows up in the system profiler) but when I connect a drive it does not mount. The drives also do not show up in disk utility. Is there something that I can do to get the firewire drives to mount. Any help will be much appreciated.
    Mike
    Paul Dickin replied 19 years ago 3 Members · 2 Replies
  • Jeremy Garchow
    August 31, 2007 at 3:46 pm
    What card? Do you need a driver?
  • Paul Dickin
    August 31, 2007 at 7:05 pm
    Hi
    OS X natively supports OHCI FireWire (or USB1.1/2) cards, so those cards (the majority?) don’t need a driver.
    If nothing connected to a card shows up in Disk Utility, then that’s a problem.
    Mostly the problem is that the attached drive does show up in DU, but if it’s Windows formatted this can’t be changed until a new Mac partition is set up.
    For onboard FW failure a motherboard PMU/SMU reset mostly brings back functionality. I don’t know if this applies to PCI cards, maybe not…
