Activity Forums Apple Final Cut Pro Legacy Add Video Transition Grayed out & View in Cinema tools
  • Add Video Transition Grayed out & View in Cinema tools
    Posted by Star Victoria on August 7, 2011 at 2:40 pm
    Hi, I did search before asking but no one seems to have really answered what my issue is. I have been using my FCP fine for almost a year. For some reason now the Add Video Transition link/button under sequence will not work. It stays grayed out even when I know it should turn to black for me to select. Also I am aware you cannot use transition on clips without trimming it a bit so that is not the issue, it just wont turn black for me to select at all, indefinitely. I am also getting the same issue with the View-Open in Cinema tools. It stays grayed out and I can’t select it either. Any thoughts?? Your help is greatly appreciated.
    Star
    Star Victoria replied 15 years, 1 month ago 2 Members · 2 Replies
  • Jerry Hofmann
    August 8, 2011 at 2:07 pm
    Is an edit point selected in your sequence when you attempt to add a transition?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Star Victoria
    August 10, 2011 at 1:17 am
    Hi Jerry,
    Yes, edit points selected but no avail. It’s just totally grayed out no matter what I do, trim, blade, put the selection tool between edits, even selecting the whole clip. Still grayed out no matter what. Very strange.
