Add to secondary storyline, storyline grows left instead of right?
Is this possible in FCP X?
I want to add a clip to the beginning of a secondary storyline, however I don’t want the existing clips to slide downstream. I want the container of the storyline to grow left to accommodate the new clip.
What I can do is let the secondary storyline grow right when I add the clip to the head, then slide the whole storyline back left the same duration as the clip I added. But that’s more work.
Please watch this, it will show you exactly what I mean… https://vimeo.com/113749692
Thank you, in advance, for your ideas.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
