Activity Forums Adobe After Effects Expressions Add something to a selected group of a shapelayer
  • Add something to a selected group of a shapelayer
    Posted by Fabian Brugger on May 8, 2023 at 12:58 pm
    Hallo, so i want to add something, for example a trim path effekt, to a shapelayer. That works with the script below but how could i change the script so it will put the effekt on a the selected group of the shapelayer?
    var comp = app.project.activeItem;
    var layers = comp.selectedLayers;
    for (var i = 0; i < layers.length; i++) {
    if (layers[i] instanceof ShapeLayer) {
    var propertyOne = layers[i].property(“ADBE Root Vectors Group”);
    propertyOne.addProperty(“ADBE Vector Filter – Trim”);
    There is the code: selectedProperties, but i dont know how to implement this into my script.
    Fabian Brugger replied 3 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 8, 2023 at 4:37 pm
    Try this:
    var props = comp.selectedProperties;
    for (var i = 0; i < props.length; i++) {
    if (props[i].matchName == "ADBE Vector Group"){
    props[i].property("ADBE Vectors Group").addProperty("ADBE Vector Filter - Trim");
  • Fabian Brugger
    May 9, 2023 at 8:11 am
    Thank you Dan!
    I almost had the same but i mistakenly left the Line:
    in the same place and i think it broke the code as a property cant is obviously not a shapelayer 🙂
