Activity › Forums › Apple Final Cut Pro Legacy › Add logo to end of text crawl
Posted by Jacob Resendez on February 22, 2010 at 4:28 pmi have a text crawl that needs to have the company logo trailing at the end. what is the best way to do this?
thanks in advance
Jacob Resendez replied 16 years, 6 months ago 3 Members · 3 Replies -
Mark Suszko
February 22, 2010 at 5:27 pmThere are several. Here’s two. In Final Cut, just add the logo to another layer using alpha channel transparency, and in the timeline, use the motion tab and keyframing to hide it off the bottom of the screen and then reveal it at a speed that matches the text roll. You can keyframe it to stop mid-screen and fade out, or to continue up past the top of the screen and roll off. This is what I’d probably do myself.
You can do this part in Apple Motion and then import it as a a clip, layering it as discussed before.
And I may be wrong on this one, but you *might* be able to bring the element into Live Type and make it roll along with your text.
Tony Brittan
February 23, 2010 at 2:50 amIf you have LiveType, that’s your best bet. Super easy there! Not included in FCS3 but you can install it from previous versions of FCS.
Tony Brittan
Apple Certified Pro – FCP
islandshoreproductions.com -
Jacob Resendez
February 25, 2010 at 3:20 pmthanks guys. this helps a bunch.
Tony, i was up against a time crunch and settled for AE and import a .mov to lay over my clip. i did this before i received your post but i will give this a try as well. AE might not be the best idea (or might be) but it got the job done to get my comp out for the client.
Mark, i will also give the alpha channel scenario a shot too. I figured FCP had this option, just couldnt put it all together in my head fast enough.
i took over this project at work because we lost our editor. luckily, most of the work has already been done. i will eventually have to get this out for broadcast. what is the best route i should take so that i can ensure the quality of my crawl and logo are at its best? my AE cut looks fine, on a monitor of course, but i just want to make sure it will translate to the TV.
thanks again for your help!!
