Activity Forums Adobe After Effects add Lens Blur effect using composition
  • add Lens Blur effect using composition
    Posted by Max Rusakovich on April 16, 2015 at 10:09 am
    Hello!
    I want to achieve this result
    I try to create new comp COMP1 add shapes, add adjustment layer, but adjustment layer influence on shapes.
    Then I create adjustment layer in my main composotion, add lens blur, use Blur Map.
    But I can’t animate this map!
    Maybe you know more simple solution.
    I want to create amimated layer with text that can blur background at the main composition.
    Thank you
    Max Rusakovich replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
