Activity Forums Adobe After Effects Expressions Add keyframe on current Time
  • Add keyframe on current Time
    Posted by Sebastian Moreno on June 7, 2016 at 6:58 pm
    Simple but weird. I can’t get to use addKey where the Current time indicator stands. I just want to add a key frame to the shape layer:
    opaCity = shapeLayer.property(“Transform”).property(“Opacity”).setValue(0);
    btn6.onClick = function(){
    shapeLayer.property(“Transform”).property(“Opacity”).addKey(KeyframeTime);
    ////I tried this and other couple of things for this” KeyframeTime”:
    KeyframeTime = app.project.items.testComp.layers.shapeLayer.keyTime(1). — and isnt working
    Sebastian Moreno replied 10 years, 1 month ago 2 Members · 2 Replies
  • Mike Sevigny
    July 4, 2016 at 6:17 pm
    You need to identify where the timeline indicator is currently positioned in time
    activeComp = app.project.activeItem; // Collect the active composition
    keyTime = activeComp.time; // Identify the current position of the timeline indicator
    opaCity = shapeLayer.property("Transform").property("Opacity"); // Identify your opacity parameter
    opaCity.addKey(keyTime); // Add keyframe
    opaCity.setValueAtTime(keyTime, 50); // Set the keyframe's value to 50
    Mike Sevigny
  • Sebastian Moreno
    July 7, 2016 at 5:43 pm
    Ohhh Mike thank you
    I didn’t know about this active syntax and the combination of addKey and setValue.
    Brilliant.
    Thanks again
