Activity Forums Adobe After Effects Add flicker.
  • Kevin Camp
    May 31, 2007 at 3:25 pm
    you’re talking about the phase issue that you see when a crt tv’s or montior’s refresh rate doesn’t jive well with the shutter speed of the camera and you see a dark band repeatedly move down the screen?
    i think all you really need to do is create a loop of a solid that is about one fifth of the comp’s height that moves down the screen over about 2 seconds or so. drag that into your video screen comp adjust opacity, maybe blending mode and you shold be getting pretty close.
    Kevin Camp
    Designer – KCPQ, KMYQ & KRCW
  • Steve Roberts
    May 31, 2007 at 5:58 pm
    Try searching the COW for “flicker” and “wiggle”.
