Activity Forums Apple Final Cut Pro Legacy Add Fade then the crop setting changes over the course of the fade
  • Add Fade then the crop setting changes over the course of the fade
    Posted by Adam Howden on May 5, 2005 at 3:42 am
    Ok. So here is the situation. i have a standard DV Pal clip on a timeline set to DV Pal etc all normal. I have added a crop of 1 to both top and bottom to get rid of some bad line that is at the bottom of the DV footage. I have then added a fade and what happens is when the fade of 1 sec goes from black to full picture the crop of 1 adjusts over that time period. ie. Start of the frame no crop, by the time the picture is fully exposed the crop is there! you can see it move?
    I have also noticed this with things like a cross disolve where the framing of the picture slightly re adjusts through the cross fade. Does anyone know what this is, its not dramatic but if you want to be anal about things its notiicable 🙂
    cioa for now…
    1 X Dual 2GHZ G5
    2.5 GIG RAM
    1 X Decklink Pro
    1 X UL3D SCSI CARD
    2 X SEAGATE 10K 136 GIG SCSI Drives Software RAID
    FCP 4.5, DVD SP 3, AE 5.5, Photoshop 7, Motion
    Kevin Monahan replied 21 years, 4 months ago 3 Members · 2 Replies
  • Bill
    May 5, 2005 at 12:22 pm
    try rendering out the cropped clip….. try using a keyframe opacity change instead of a fade /dip to color/cross dissolve. and for the obvious make sure you don’t have a key frame on the crop.
  • Kevin Monahan
    May 5, 2005 at 6:40 pm
    Crop, nest the cropped clip, then fade the nest. This is explained in my book….it’s called “tricking the render pipeline”.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
