Activity › Forums › Avid Media Composer › Add Edit Keys (a quick question)
  • Don Days
    June 17, 2005 at 6:28 pm
    Go to previous/next edit will take you into trim mode. If you want to navigate edit by edits on the timeline then use your FF/RW keys and make sure to set them to stop at either heads or tails in you composer settings.
