Activity Forums Adobe After Effects add 2D fog to a 3D anim with moving cam
  • add 2D fog to a 3D anim with moving cam
    Posted by Renderfoo on December 20, 2006 at 9:12 am
    I know there are many posts in this forum concerning fog but I can’t find a solution for my problem 🙁
    I made an animation in Cinema 4D. The Camera is moving in all directions. Now I want to add some fog to this animation. I tried several things:
    in C4D:
    the only way to create the fog directly in C4D without waiting endlessly for the rendering is to use visible lights but I couldn’t get results that were quite convincing.
    in AE:
    Now I tried to add the fog in AE. I used the “fog factory” from “Digieffects Delirium” and that looks brilliant for me 🙂 The problem is the moving camera. When the camera is pointing to the left and moving forward in the rendering of my 3D-anim then the 2D-fog should behave accordingly. Of course I can do it by hand: when I scrub forward in the anim and see the cam is changing the position, I change the offset settings in the “fog factory” effect. When the cam is moving forward I change the size of the fog. Is there any way to do this automatically via some expression ?
    Mylenium replied 19 years, 9 months ago 2 Members · 3 Replies
  • Mylenium
    December 20, 2006 at 12:17 pm
    I’m sure it could be done, but I don’t know that particular effect. If I get around to downloading it, I might take a look at it and have something (no promises, though, as I often forget).
    Mylenium
    [Pour Myl
  • Renderfoo
    December 20, 2006 at 12:28 pm
    That would be great ! Thanks already for looking after this effect !
  • Mylenium
    December 20, 2006 at 5:27 pm
    I’m sorry, but the demo version of the Delerium suite only shows me DE_Glower and DE_Fireworks. Can’t help you then. :-[
    Mylenium
    [Pour Myl
