Activity Forums VEGAS Pro Adapt 25fps in 50 with “alpha” frames
  • Adapt 25fps in 50 with “alpha” frames
    Posted by Alain Azpeitia on May 3, 2017 at 11:35 pm
    I want to put a 25fps video in a 50fps edit but the frames repeat like this to get 50 fps full of images:
    1-1-2-2-3-3….24-24-25-25
    I want to create blank empty and transparent frames betweem them, so if i add a video in a layer below it I could see it.
    1-transparent-2-transparent…24-transparent-25
    How can I do that?
    Thanks.
    Alain Azpeitia replied 9 years, 4 months ago 2 Members · 2 Replies
  • László Kovács
    May 4, 2017 at 6:14 pm
    I know I’m repeating myself, but my only idea is to take Vegasaur in such a case.
    You can achieve what you want using Vegasaurs “strobe light effect”.
    Set Duration, pause duration to exactly 1 frame, fade duration to zero.
    That creates a composite level envelope for you on the selected track over the selected time range.
    Best regards
    László Kovács
  • Alain Azpeitia
    May 6, 2017 at 10:18 am
    Thank you very much! It worked like a charm! 🙂
