Activity Forums Boris FX Particle Illusion Activation code
  • Activation code
    Posted by Paul Hansen on January 23, 2011 at 5:29 am
    Alan… For some reason, when I tried to open PI this evening, it asked for my activation code and the couple I have didn’t work. I have no idea what made it do that. Do I need a new activation code?
    Paul
    Alan Lorence replied 15 years, 6 months ago 4 Members · 13 Replies
  • 13 Replies
  • Alan Lorence
    January 24, 2011 at 7:28 pm
    Sounds like it. If you have removable drives, remove them all, then activate. Then you should be able to add/remove drives without problems.
    If you didn’t add/remove any drives, did you update any hardware on your system?
    Alan.
    http://www.wondertouch.com
  • Paul Hansen
    January 25, 2011 at 6:04 pm
    Didn’t add or remove any hardware. I think I did the upgrade on PI and then a # of the emitters (from 9-9l on) didn’t show up so downloaded them again but the Last group of emitters (10-12) didn’t show with I opened PI even though it appeared in my emitters folder. So… I copied it from my desk top and replaced it in the emitters folder and that’s when PI asked me for my activation code.
    compulsively creative
  • John Orban
    January 31, 2011 at 2:00 pm
    I’ve got exactly the same problem. About a month or so ago PI started asking for an activation code.
    Not only does it ask for an activation code, but then after a couple of minutes, the program crashes.
    Running 10.6.6 Mac OSX – MacPro – 16GB RAM
    I have an iMac @ home that works just fine. Only difference is a single processor vs dual-processors @ work (which is the machine that crashes the app).
    No new hardware – regular software updates from Apple
    Process: particleIllusion [5657]
    Path: /Applications/particleIllusion 3.0/particleIllusion.app/Contents/MacOS/particleIllusion
    Identifier: com.wondertouch.pIllusion_308
    Version: particleIllusion version 3.0.8.1 (3.0.8.1)
    Code Type: X86 (Native)
    Parent Process: launchd [161]
    Date/Time: 2011-01-31 08:55:48.060 -0500
    OS Version: Mac OS X 10.6.6 (10J567)
    Report Version: 6
    Interval Since Last Report: 493117 sec
    Crashes Since Last Report: 1
    Per-App Interval Since Last Report: 132 sec
    Per-App Crashes Since Last Report: 1
    Anonymous UUID: 09B1A11A-456C-41EE-93EC-E17BD7BFAF3F
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    Crashed Thread: 0 Dispatch queue: com.apple.main-thread
  • Paul Hansen
    January 31, 2011 at 7:14 pm
    Wow! That sounds complicated! I got a new activation code and now PI works fine… the only thing… I downloaded the latest group of emitters (emitters_10_12) and they downloaded to my document folder and said they had to be moved to my emitters folder by me. I did this and then they didn’t show up when I opened PI. Guess I will just live without them! I am a little gun shy of messing around with the program anymore!
  • Billy Page
    January 31, 2011 at 10:57 pm
    I am going thru the same problem and have had to reactivate twice so far. It started right after I downloaded the latest update to PI3.
  • Alan Lorence
    January 31, 2011 at 11:32 pm
    Are you ever seeing a “File Damaged” message?
    If so, it means you’re trying to open a second copy of pI3 (it’s already open). The old version gave you the message but left the license, while the new version resets the license (an unintended side effect of a change to fix something else).
    So, are you seeing the “file damaged” message?
    Alan.
  • Paul Hansen
    February 1, 2011 at 3:35 am
    Nope, not getting any “file damaged” message
  • Alan Lorence
    February 1, 2011 at 1:11 pm
    You would only see that message one time, then you would lose your activation.
    Alan.
  • Paul Hansen
    February 1, 2011 at 4:34 pm
    As far as I know, I never saw that message. Do you know why my reactivated PI won’t recognize the latest emitter group?
  • Alan Lorence
    February 1, 2011 at 8:12 pm
    Actually, I think I figured it out. Check both of these folders:
    C:\Program Files (x86)\particleIllusion 3.0\Emitter Libraries
    C:\Program Files\particleIllusion 3.0\Emitter Libraries
    It may be that the update uses the first path on 64-bit Windows (incorrectly), while the old version uses the second. Copy any emitters missing from one to the other and you should be set.
    That’s my theory at least.
    Alan.
