Activity › Forums › Adobe Premiere Pro › Acquire 4-channels of audio via Firewire?
  • Acquire 4-channels of audio via Firewire?
    Posted by James Orlowski on September 19, 2007 at 3:12 pm
    Anyone know if it’s possible to acquire content from our Sony DSR-2000A deck via Firewire (i.Link) and KEEP the 4-channels of audio in tact and separated?
    Or, as a second alternative, is it possible to have the output of the deck MIX all 4 channels down to two and output the content via the Firewire port?
    Or, is video pumped thru Firewire only ever 2 channels?
    We’re trying this now, but all we hear on the PC end is channels 1 and 2. Channels 3 and 4 are completely ignored.
    Thanks.
    James Orlowski
    RYNO Production, Inc.
    http://www.rynoproduction.com
    800-860-7966
    Mike Velte replied 19 years ago 4 Members · 4 Replies
  • Vince Becquiot
    September 19, 2007 at 3:35 pm
    I think you will have to get channels 3/4 sparately.
    I don’t have this particular unit, but there should be a way to select which channels you want to output.
    Vince
  • Blast1
    September 19, 2007 at 7:36 pm
    If you are trying to capture 4 ch DV sound look into scenalyzer,
    https://www.scenalyzer.com
  • James Orlowski
    September 20, 2007 at 10:11 am
    If I capture with Scenalyzer, can the files be imported into Premiere? If so, how would Premiere handle the footage?
  • Mike Velte
    September 20, 2007 at 11:32 am
    In Scenalyzer (File>Options>Capture settings>File type) choose Type 2 DV for Premiere.
    Scenalyzer will output an addition wave file if you select Second channel in Options just below above.
