Activity › Forums › Adobe Illustrator › Acid artwork problem
  • Acid artwork problem
    Posted by Kimmi Traeger on August 16, 2016 at 11:37 am
    I’ve been trying to make similar style pattern as the background of the attached picture without much luck.
    I assumed it would be fairly easy just using Zig Zag effect on a circle, user some gradients and layer the artwork, but it just doesn’t look right.
    Does anyone have any suggestion how to make this kind of marbled/rave/acid pattern?
    Kimmi Traeger replied 10 years, 1 month ago 3 Members · 6 Replies
  • Kalleheikki Kannisto
    August 16, 2016 at 2:21 pm
    That’s more of a Photoshop effect. Once you have created the basic repeating spectrum, use a Wave warp effect (in vertical direction only) followed by polar coordinates.
    Senior Graphic Designer
  • Kimmi Traeger
    August 16, 2016 at 3:51 pm
    Hi Kalle
    Thank you for getting back to me.
    Do you mean use Polar coordinates in photoshop?
    I’ve tried two set-ups in illustrator see attched picture and transfered the artwork to Photoshop to use the ‘Polar Coordinate’ effect. It definitely returns an interesting effect, though not exactly what I was looking for.
  • Anju Bala
    August 16, 2016 at 7:07 pm
    in illustrator ,you can do in simple steps by simply making the colored circles and then use effect > wrap>wave
    or you can do it by wrinkle tool from the tool panel in illustrator.
    August 17, 2016 at 6:27 pm
    In Photoshop:
    1. Create a spectrum gradient. Copy it a few times so it repeats.
    2. Use Wave warp to roughen it vertically.
    3. Use polar coordinates (rectangular to polar) and scale up so the warped area fill the canvas.
    You can make something similar in Illustrator, it’s just easier in Photoshop.
  • Kimmi Traeger
    August 18, 2016 at 8:12 pm
    Amazing, Thank you so much.
  • Kimmi Traeger
    August 18, 2016 at 8:13 pm
    Amazing, thank you so much… It works
